Jan 09, 2024Guru - Experienced User
ComCast/XFinity Next Generation ISP FAQ
For anyone using these two ISP, it's recommended to review there information regarding there newer ISP services:
https://www.reddit.com/r/Comcast_Xfinity/wiki/knowledgebase/next-generation-internet/
During this phase there maybe some problems that arise from this change in services and use with NETGEAR branded cable modems and gateways.
Users are encouraged to reach out to these ISPs directly, should there be any questions or problems seen with there services.
This ISP updates there compatible modems list here:
Users should review General Troubleshooting Information if they have any NETGEAR branded modem in use with these ISPs:
https://www.xfinity.com/support/articles/upgraded-areas-leased-equipment-required-for-upload-speeds
Please post the following information in the forums so we can help troubleshoot problematic issues that maybe seen with NETGEAR cable modems and cable gateways:
Copy and paste of the modems connection status and event log page data.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
Thank you.
- KitsapMaster
Evidence at least the process is still alive. Xfinity released a new list updated 06/26/2024.
- donawaltMentor - Experienced User
If you haven't heard, Comcast has increased upload speeds on its mid-split network again, after a recent upgrade this year.
You can read about it on this Reddit thread, but the 1000/100 plan moves to 1000/150. The 1200 plan actually gets increased upload AND download speeds, going from 1200/200 to 2000/300. There will be no more 1200 plan. The 2G plan, 2000/200, goes to 2000/300.
There are other changes, as there are supposedly a consolidated group of tiers now - with download speeds of 150/300/500/1000/2000 Mbps.
It will show up on your account page/plan info if you have it. You need to be in an area where mid-split conversion is complete, and you need Comcast-approved mid-split compatible modem.
You may have to power cycle your modem to see it, I did.
