csosa's avatar
csosa
Follower
Apr 16, 2016
Devices cannot conect to guest network C6300
Almost all of the devices I try to connect to my c6300 cable modem router show they are connected but only have limited access. The devices unable to connect are  andriod tablets, iphones and windows 8 computers. How do I fix this issue?
Firmware Version
V2.01.14
  • Thank you for ALL of your assistance.  I did the factory reset and it seems all is good.  All four networks are working fine (that includes both guest networks).  Mahalo!!
  • Do you have Access Control enabled under ADVANCED > Security > Access Control?
    • djfriend's avatar
      djfriend
      Tutor
      Yes, Access Control is enabled, but still no internet access using guest networks.
      • TheEther's avatar
        TheEther
        Guru
        Since you have Access Control enabled, you have to add your devices to the access list.  Otherwise, they will not be able to access the Internet.
