Afkinch's avatar
Afkinch
Devices losing connection with c6300 repeatedly
Devices lose internet. Restart device and gets reconnected. Constant ping shows sporadic higher return times hundreds ms. Clears up then has a regular spike.
We have about 20 devices on. Connect via cat5 and no issues.
  • Equipment: Netgear C6300
    Computer: HP Laptop
    Connection:  Wireless connection
    Ethernet: Shows no issues when I connect to it.
    Problem: Computer responds terribly slow at intermittent times.
    Troubleshooting conducted:
    Ran a continuous ping to gateway 192.168.0.1 and received round trips that bounce from 3ms to 300ms sporadically.
    Channel
    Lock Status
    Modulation
    Channel ID
    Frequency
    Power
    SNR
    Correct
    ables
    UnCorre
    ctables
    1
    Locked
    QAM 256
    1
    507000000 Hz
    0.2 dBmV
    40.3 dB
    58
    0
    2
    Locked
    QAM 256
    2
    513000000 Hz
    0.2 dBmV
    40.3 dB
    56
    0
    3
    Locked
    QAM 256
    3
    519000000 Hz
    0.2 dBmV
    38.9 dB
    34
    0
    4
    Locked
    QAM 256
    4
    525000000 Hz
    0.0 dBmV
    40.3 dB
    29
    0
    5
    Locked
    QAM 256
    5
    531000000 Hz
    0.0 dBmV
    38.9 dB
    29
    0
    6
    Locked
    QAM 256
    6
    537000000 Hz
    0.0 dBmV
    38.9 dB
    28
    0
    7
    Locked
    QAM 256
    7
    543000000 Hz
    0.0 dBmV
    38.9 dB
    40
    0
    8
    Locked
    QAM 256
    8
    549000000 Hz
    -0.2 dBmV
    38.9 dB
    53
    14
    9
    Locked
    QAM 256
    9
    555000000 Hz
    -0.2 dBmV
    38.9 dB
    53
    19
    10
    Locked
    QAM 256
    10
    561000000 Hz
    -0.2 dBmV
    38.6 dB
    102
    30
    11
    Locked
    QAM 256
    11
    567000000 Hz
    -0.2 dBmV
    38.6 dB
    58
    61
    12
    Locked
    QAM 256
    12
    573000000 Hz
    0.0 dBmV
    38.9 dB
    88
    32
    13
    Locked
    QAM 256
    13
    579000000 Hz
    0.0 dBmV
    38.9 dB
    64
    4
    14
    Locked
    QAM 256
    14
    585000000 Hz
    0.5 dBmV
    38.9 dB
    55
    0
    15
    Locked
    QAM 256
    15
    591000000 Hz
    0.2 dBmV
    38.9 dB
    65
    0
    16
    Locked
    QAM 256
    16
    597000000 Hz
    0.2 dBmV
    38.6 dB
    39
    20
    Upstream Bonded Channels
    Channel
    Lock Status
    US Channel Type
    Channel ID
    Symbol Rate
    Frequency
    Power
    1
    Locked
    ATDMA
    1
    5120 Ksym/sec
    17300000 Hz
    44.5 dBmV
    2
    Locked
    ATDMA
    2
    5120 Ksym/sec
    23700000 Hz
    45.3 dBmV
    3
    Locked
    ATDMA
    3
    5120 Ksym/sec
    30100000 Hz
    45.0 dBmV
    4
    Locked
    ATDMA
    4
    5120 Ksym/sec
    36500000 Hz
    45.8 dBmV
    • FURRYe38's avatar
      • Afkinch's avatar
        Afkinch
        Changed my 2.4 GHhz to channel 9, I show about 30 Access points, but there is only 4 on Channel 9; already set to manual. 5GHz has been changed as well. I have been monitoring the channels and changing when their busy.
        This problem has only recently started in the past 3 or 4 weeks. Before that I did not have a problem. Nothing recently has changed on my network. The Netgear C6300 is 3 or 4 years old.
        Was looking to see if the Netgear C6300 was at its EOL, but unable to determine that the Netgear website.
