myrmidon009's avatar
myrmidon009
DNS Settings Grayed Out
I'm trying to change the DNS Settings on my cable gateway.  It's an AC1900/C6300BD wireless cable data gateway and my internet provider is Cox.  I have logged in using the address for the modem.  However, when I go the 'Advanced Settings' and click on 'Internet Setup', the 'Use These DNS Servers' button is grayed out and I cannot click it.  Do you know why this is and how I can change it so that I can change the DNS servers?  Thank you very much.
  • I gave Cox a call.  They said that that functionality is disabled on newer modems, and they cannot change it.  Also, all future modems will have the same functionality disabled.  It's time to switch to a new ISP.  Thank you for trying to work through this with me.
  • FURRYe38's avatar
    Do you have any parental controls enabled? Disable these as these tend to use specific DNS addresses thus disabling the use of configuring the DNS addresses here.
    • myrmidon009's avatar
      myrmidon009
      Parental controls have never been enabled on the modem.  I had one previously on the computer, but it has been uninstalled.  AVG Antivirus is still active, if that might make a difference.
      I should mention that I was able to select the button after I unclicked 'Use Gateway as DHCP Server' on the 'LAN Setup' page.  But when I entered the new DNS servers and clicked 'Apply', the new addresses would not be used; the old ones would still be listed on the 'Gateway Status'.  Shortly (maybe 10 minutes) after unclicking that button, 'Use Gateway as DHCP Server', however, I was no longer able to log into the modem.  When I typed in the address, it was say that it was not able to find that page.  I had to do a factory reset of the modem to be able to log in again.
      • FURRYe38's avatar
        Wondering if your ISP is making any configuration changes to your modem. Something to ask them about.
