alexj319's avatar
Mar 09, 2020
Dropping internet multiple times a day for a few minutes - Critical Logs Interpretation
Hi all,
I have been struggling with this for the past few months. When my internet drops, neither the modem or the router show that there has been an interruption in service. I do know that power cycling the modem will get internet access back within a couple of minutes, but power cycling the router does nothing.
I have looked at the logs and have had no luck interpreting them. I am hoping someone on here can help. I can say that it does seem to happen more often during the day then at night, as I work from home and almost never notice a drop in internet past 5-6pm.
Thank you in advance.
  • if the new gateway doesn't change anything, your isp needs to check your line.
    Your upstream power levels are a little high and you've got a few error in your signal.
  • plemans's avatar
    Also get a screen snip of the modem's connections page. it shows the connection back to the isp.
    • alexj319's avatar
      alexj319
      Guide
      I do not know if it will confound things, but after the original post, I factory reset the modem again.
      Frequency start Value
      This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect.
      Starting Frequency
      <tabindex=-1>Startup Procedure</tabindex=-1>
      ProcedureStatusComment
      Acquire Downstream Channel465000000 HzLocked
      Connectivity StateOKOperational
      Boot StateOKOperational
      SecurityEnableBPI+
      IP Provisioning ModeHonor MDDIPv6 only
      <tabindex=-1>Downstream Bonded Channels</tabindex=-1>
      ChannelLock StatusModulationChannel IDFrequencyPowerSNR / MERUnerrored CodewordsCorrectable CodewordsUncorrectable Codewords
      1LockedQAM2568465000000 Hz3.2 dBmV38.2 dB17129735100
      2LockedQAM2569471000000 Hz3.2 dBmV38.3 dB17124048700
      3LockedQAM25610477000000 Hz3.4 dBmV38.2 dB17124413400
      4LockedQAM25611483000000 Hz3.3 dBmV38.1 dB17124725500
      5LockedQAM25612489000000 Hz3.4 dBmV38.0 dB17125061300
      6LockedQAM25613495000000 Hz3.5 dBmV38.2 dB17125478700
      7LockedQAM25614519000000 Hz3.8 dBmV37.9 dB17125927100
      8LockedQAM25615525000000 Hz3.7 dBmV37.9 dB17126250700
      9LockedQAM25616531000000 Hz3.8 dBmV37.8 dB17126587800
      10LockedQAM25617537000000 Hz3.9 dBmV37.8 dB17127004700
      11LockedQAM25618543000000 Hz4.3 dBmV37.9 dB17126789200
      12LockedQAM25619549000000 Hz4.2 dBmV37.9 dB17127159300
      13LockedQAM25620555000000 Hz4.4 dBmV37.9 dB17127564700
      14LockedQAM25621561000000 Hz4.5 dBmV37.8 dB17127881900
      15LockedQAM25622567000000 Hz4.4 dBmV37.8 dB17128275400
      16LockedQAM25623573000000 Hz4.6 dBmV37.0 dB17128646400
      17LockedQAM25624579000000 Hz4.6 dBmV37.3 dB17128992100
      18LockedQAM25625585000000 Hz4.7 dBmV37.3 dB17129405100
      19LockedQAM25626591000000 Hz5.1 dBmV36.5 dB17129793300
      20LockedQAM25627597000000 Hz5.3 dBmV36.9 dB17130169400
      21LockedQAM25628603000000 Hz5.2 dBmV37.8 dB17130527400
      22LockedQAM25629609000000 Hz5.1 dBmV37.7 dB17130909400
      23LockedQAM25630615000000 Hz5.3 dBmV37.8 dB17131183400
      24LockedQAM25631621000000 Hz5.4 dBmV37.8 dB17131625100
      25LockedQAM25632627000000 Hz5.7 dBmV37.7 dB17132043300
      26LockedQAM25633633000000 Hz5.6 dBmV37.8 dB17132322300
      27LockedQAM25634639000000 Hz5.0 dBmV37.8 dB17132770400
      28LockedQAM25635645000000 Hz5.0 dBmV37.5 dB17133139900
      29LockedQAM25636651000000 Hz5.1 dBmV37.6 dB17133327300
      30LockedQAM25637657000000 Hz5.0 dBmV37.6 dB17133495600
      31LockedQAM25638663000000 Hz5.0 dBmV37.6 dB17133388600
      32Not LockedUnknown00 Hz0.0 dBmV0.0 dB000
      <tabindex=-1>Upstream Bonded Channels</tabindex=-1>
      1LockedATDMA4536500000 Hz50.5 dBmV
      2LockedATDMA4630100000 Hz51.8 dBmV
      3LockedATDMA4723700000 Hz52.0 dBmV
      4LockedATDMA4817300000 Hz51.8 dBmV
      5Not LockedUnknown00 Hz0.0 dBmV
      6Not LockedUnknown00 Hz0.0 dBmV
      7Not LockedUnknown00 Hz0.0 dBmV
      8Not LockedUnknown00 Hz0.0 dBmV
      <tabindex=-1>Downstream OFDM Channels</tabindex=-1>
      ChannelLock StatusModulation / Profile IDChannel IDFrequencyPowerSNR / MERActive Subcarrier Number RangeUnerrored CodewordsCorrectable CodewordsUncorrectable Codewords
      1Locked0, 1, 2, 348805000000 Hz4.4 dBmV35.3 dB1168 ~ 2927555911629254160
      2Not Locked000 Hz1.2 dBmV0.0 dB0 ~ 4095000
      <tabindex=-1>Upstream OFDMA Channels</tabindex=-1>
      1Not LockedUnknown00 Hz0 dBmV
      2Not LockedUnknown00 Hz0 dBmV
      Current System Time: Mon Mar 09 10:43:42 2020 System Up Time: 1:05:55
  • FURRYe38's avatar
    Have the ISP check the signal and line quality UP to the modem.
    Be sure there are not coax cable line splitters in the between the modem and ISP service box.
    Be sure your using good quality RG6 coax cable up to the modem.
    alexj319 wrote:
    Hi all,
    • plemans's avatar
      Like FURRYe38 said, check your coax connectors and lines. A cheap connector/splitter can cause many issues.
      Let it run for a while and re-post that connections page. If this is fresh off a factory reset, you're not going to see the errors/problems. If its intermittent, wait until you have an issue, then log into this page and screen snip it.
      • alexj319's avatar
        alexj319
        Guide
        @FURRYe38plemans
        The drops have been occurring all day. They seem to be getting worse, shorter intervals between drops, and longer intervals before the internet comes back.
        I have now connected a new gateway (vs. my modem & router combo), and will report back if that changes anything.
        Here is the connection page and logs.
        Starting Frequency
        Startup Procedure
        Procedure
        Status
        Comment
        555000000 Hz
        Locked
        Connectivity State
        OK
        Operational
        Boot State
        OK
        Operational
        Security
        Enable
        BPI+
        Honor MDD
        IPv6 only
        Channel
        Lock Status
        Modulation
        Channel ID
        Frequency
        Power
        SNR / MER
        Unerrored Codewords
        1
        Locked
        QAM256
        20
        555000000 Hz
        1.0 dBmV
        37.8 dB
        9228881
        4621
        607
        2
        Locked
        QAM256
        17
        537000000 Hz
        0.7 dBmV
        37.8 dB
        9229935
        5064
        691
        3
        Locked
        QAM256
        18
        543000000 Hz
        1.0 dBmV
        38.0 dB
        9234486
        4143
        655
        4
        Locked
        QAM256
        19
        549000000 Hz
        0.8 dBmV
        37.9 dB
        9237883
        4463
        561
        5
        Locked
        QAM256
        21
        561000000 Hz
        1.2 dBmV
        37.9 dB
        9241584
        4787
        700
        6
        Locked
        QAM256
        22
        567000000 Hz
        1.2 dBmV
        37.8 dB
        9245113
        5192
        539
        7
        Locked
        QAM256
        23
        573000000 Hz
        1.4 dBmV
        37.0 dB
        9248631
        4985
        565
        8
        Locked
        QAM256
        24
        579000000 Hz
        1.3 dBmV
        37.4 dB
        9252577
        5223
        453
        9
        Locked
        QAM256
        25
        585000000 Hz
        1.2 dBmV
        37.4 dB
        9256479
        4781
        520
        10
        Locked
        QAM256
        26
        591000000 Hz
        1.7 dBmV
        36.8 dB
        9260538
        4374
        369
        11
        Locked
        QAM256
        27
        597000000 Hz
        1.9 dBmV
        36.9 dB
        9264677
        4287
        355
        12
        Locked
        QAM256
        28
        603000000 Hz
        2.0 dBmV
        37.5 dB
        9268582
        3920
        313
        13
        Locked
        QAM256
        29
        609000000 Hz
        2.0 dBmV
        37.7 dB
        9272723
        3751
        274
        14
        Locked
        QAM256
        30
        615000000 Hz
        2.1 dBmV
        37.8 dB
        9276530
        3502
        256
        15
        Locked
        QAM256
        31
        621000000 Hz
        1.9 dBmV
        37.9 dB
        9280399
        3454
        256
        16
        Locked
        QAM256
        32
        627000000 Hz
        2.1 dBmV
        37.8 dB
        9284047
        3485
        226
        17
        Locked
        QAM256
        33
        633000000 Hz
        2.0 dBmV
        37.8 dB
        9287876
        3667
        265
        18
        Locked
        QAM256
        34
        639000000 Hz
        1.7 dBmV
        37.8 dB
        9290914
        3949
        315
        19
        Locked
        QAM256
        35
        645000000 Hz
        1.8 dBmV
        37.6 dB
        9295417
        3189
        269
        20
        Locked
        QAM256
        36
        651000000 Hz
        1.8 dBmV
        37.6 dB
        9299162
        3139
        231
        21
        Locked
        QAM256
        37
        657000000 Hz
        1.4 dBmV
        37.6 dB
        9302659
        3676
        283
        22
        Locked
        QAM256
        38
        663000000 Hz
        1.2 dBmV
        37.7 dB
        9306265
        3502
        207
        23
        Locked
        QAM256
        39
        669000000 Hz
        1.6 dBmV
        37.8 dB
        9310872
        2661
        141
        24
        Locked
        QAM256
        40
        675000000 Hz
        1.8 dBmV
        37.5 dB
        9315522
        2007
        153
        25
        Locked
        QAM256
        41
        681000000 Hz
        1.7 dBmV
        37.5 dB
        9318835
        2116
        141
        26
        Locked
        QAM256
        42
        687000000 Hz
        1.8 dBmV
        37.4 dB
        9323822
        1043
        116
        27
        Locked
        QAM256
        43
        693000000 Hz
        1.7 dBmV
        37.6 dB
        9328237
        582
        115
        28
        Locked
        QAM256
        44
        699000000 Hz
        1.3 dBmV
        37.5 dB
        9331826
        646
        113
        29
        Locked
        QAM256
        45
        705000000 Hz
        1.8 dBmV
        37.6 dB
        9335314
        799
        119
        30
        Locked
        QAM256
        46
        711000000 Hz
        1.9 dBmV
        37.6 dB
        9336129
        800
        109
        31
        Locked
        QAM256
        47
        717000000 Hz
        2.0 dBmV
        37.6 dB
        9335774
        733
        106
        32
        Not Locked
        Unknown
        0
        0 Hz
        0.0 dBmV
        0.0 dB
        0
        0
        0
        Channel
        Lock Status
        Modulation
        Channel ID
        Frequency
        Power
        1
        Locked
        ATDMA
        45
        36500000 Hz
        51.8 dBmV
        2
        Locked
        ATDMA
        46
        30100000 Hz
        53.5 dBmV
        3
        Locked
        ATDMA
        47
        23700000 Hz
        54.0 dBmV
        4
        Locked
        ATDMA
        48
        17300000 Hz
        53.8 dBmV
        5
        Not Locked
        Unknown
        0
        0 Hz
        0.0 dBmV
        6
        Not Locked
        Unknown
        0
        0 Hz
        0.0 dBmV
        7
        Not Locked
        Unknown
        0
        0 Hz
        0.0 dBmV
        8
        Not Locked
        Unknown
        0
        0 Hz
        0.0 dBmV
        Channel
        Lock Status
        Channel ID
        Frequency
        Power
        SNR / MER
        Unerrored Codewords
        1
        Locked
        0, 1, 2, 3
        48
        805000000 Hz
        1.1 dBmV
        35.3 dB
        1168 ~ 2927
        248600
        117904
        15
        2
        Not Locked
        0
        0
        0 Hz
        -1.7 dBmV
        0.0 dB
        0 ~ 4095
        0
        0
        0
        Channel
        Lock Status
        Channel ID
        Frequency
        Power
        1
        Not Locked
        Unknown
        0
        0 Hz
        0 dBmV
        2
        Not Locked
        Unknown
        0
        0 Hz
        0 dBmV
        Current System Time: Mon Mar 09 15:54:27 2020
        System Up Time: 0:04:13
