fd1
Nov 30, 2020Aspirant
Dropping of internet connection
In recent days my Cox cable internet connection has been lost a couple of times for a number of hours straight but both times it came right by itself. Cox is advising that there have been no known outages and after various attempts of troubleshooting tonightt they say its a modem issue.
Rebooting of the modem/router hasn't helped so far but I notice in the event log that under the cable connection on the connectivity state line the comment is "Access Denied". The internet port screen is, beside the MAC details, completely empty. Any suggestions where this issue might lie as I am not ocnvinced this is a router issue.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute them back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853- FURRYe38Guru - Experienced User
Glad you got it fixed. Please mark your thread as solved, so others will know.
Enjoy.
- Hoo-DooTutor
fd1 How long had the unit been trying to come on line before you took that screenshot? Also, please post a new screenshot with all the Downstream and Upstream channel info visible. Paste into Paint, crop as needed, save as .jpg, then attach to reply. You can leave out everything above "Downstream Bonded Channels."
Any progress on this?
fd1 wrote:In recent days my Cox cable internet connection has been lost a couple of times for a number of hours straight but both times it came right by itself. Cox is advising that there have been no known outages and after various attempts of troubleshooting tonightt they say its a modem issue.
