paulrjacobs's avatar
Dec 09, 2020
Ethernet Ports not working
I have a C7000v2.  Ethernet Port 1 is always green even if nothing is plugged into it.  I never show any device that's plugged into any of the ports under 'Wired' in 'Attached Devices' even with many combinations of devices and cables.  I have in the past but not now.
The green and yellow lights seem to work for the other ports.  If I do Show Statistics I show traffic on the ports other than 1 when they are plugged in but not when they are not.
Any thoughts?  I'm assuming the ethernet ports are dead/screwed up but maybe someone has other ideas?
  • FURRYe38's avatar
    If you disconnect all wires including the coax cable, pull the power cord from the wall out late for 30 seconds then plug back in, does this change anything?
      • FURRYe38's avatar
        with call cables disconnected, press the reset button for 15 seconds then release?
