LowGeared1's avatar
LowGeared1
Ethernet switch or hub or ???
Dumb question?
This system forced me to enter a model so I did but I lied as I don't have a model.
I have 2 ethernet devices and my router has one available ethernet port.  I'm looking for a device (switch or hub or ??) which will allow me to be able to dictate which of the two devices has access to that one ethernet port on the router.  Ideally the device would come with a remote control so I could sit on my fat rear and do the switching from the couch.  But it's O.K. if I have to get up and push a switch in order to make the connection.
Is what I'm looking to do even possible?
Thanks
  • > Dumb question?
       No, but describing your equipment as "my router" is less than
    helpful.
    > port.
       What, exactly, is your "my router"?  Define "available".  How many
    Ethernet ports does it have, in total?
    > [...] Is what I'm looking to do even possible?
       That may depend on exactly what your "my router" is.  If your "my
    router" really is a router, then you should be able to use an Ethernet
    switch (or hub) to expand the number of available ports.
       If your "my router" really is a modem (only, not a router), then you
    should probably add a router rather than a switch.
       Nowadays, an Ethernet hub is gettng hard to find.  An Ethernet switch
    costs about the same, and performs better in most cases.
    > [...] Ideally the device would come with a remote control so I could
       No, _ideally_, the device would let you connect mutiple devices at
    the same time, and not make you worry about which one is connected.  A
    router, perhaps with a switch, should do that.  The only mystery is what
    you already have, which would affect what you should get.
    • LowGeared1's avatar
      LowGeared1
      Thanks for the info.  Obviously I know so little about this that I don't know what information I should be providing.
      The system in question is from Charter Spectrum and consists of a Cisco DPC3216 modem and a Sagemcom Fast 5260 router.
      In addition to being wireless, the router has 4 ethernet ports.
      The uses I have for the one remaining unused port are 1) for a computer that's used for doing things like watching YouTube or other videos that are available on the internet.  2) a Sony blue-ray device.  Every now and then we want to use the Sony to connect to Amazon prime videos.
      I can't envision ever wanting the 2 devices to be operating at the same time.
      The output of these devices goes to our TV via an HDML switch (Octava UHD41-ARC).
      Thanks again.
      • antinode's avatar
        antinode
        Guru
        > [...] and a Sagemcom Fast 5260 router.
           Ok.  It's a router.
        > [...] If your "my router" really is a router, then you should be able
        > to use an Ethernet switch (or hub) to expand the number of available
        > ports.
           Still true.  Invest the $20 or so in a 5- or 8-port gigabit Ethernet
        switch.  Connect one of its ports to "the one remaining unused port" on
        the router.  Bask in the luxury of the remaining ports on your new
        gigabit Ethernet switch.
        > same time.
           Doesn't matter.  If you ever did find anything which would do what
        you had in mind (some kind of Ethernet A-B switch), then it'd probably
        cost more than the right thing, a (hub-like) gigabit Ethernet switch.
        The fact that there isn't even a good name for what you wanted should be
        a clue.  "Ethernet switch" is already in use for what you should have
        wanted.
           A Web search for "difference between Ethernet hub and switch" should
        explain that, if you're interested.
        > UHD41-ARC).
           "HDMI"?  That's a different problem.
