gmangi
Jan 31, 2021Guide
False advertising
I purchased a brand new c7000 for $170 through amazon. Upon recieving the NEW router and modem, when attempting to register the device, it was already registered under another use! They had to verify...
michaelkenward
Feb 01, 2021Guru - Experienced User
This happens regularly and has nothing to do with second-hand stuff. It seems to be something that happens at Amazon. Things seem to leave the warehouse with registration issues.
For human intervention, try this:
NETGEAR Product Registration FAQ | Answer | NETGEAR Support
But you shouldn't need it.
gmangi wrote:
Even further when I finally got the "New" device under my account, I couldn't get past the previous owner's security questions that had already been set up!
There is a bug in Netgear's implementation of password recovery on some devices. You can get locked into a closed loop.
If password recovery is enabled, but you have not set the answers to the questions, it keeps sending you back to the beginning of the process. If you haven't already given the thing your personal answers, they are not in its memory and it has no way of knowing if they are correct.
This bit is baffling:
gmangi wrote:
Spent over 3 hours on the phone with netgear with being put on hold for 30 minutes twice. I even had to call a second time after the first person I first spoke with said they would call back if we got disconnected. They never did. Then when they said they were going to escalalte the issue, they wouldn't get back to me for 3 hours.
You don't need to spend a nanosecond on line to find the answer.
Even if they exist, a factory reset will instantly eliminate any old password and security questions.
How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
Any support person would know that instantly. It is the first thing anyone will advise.
For more help, visit the support pages:
Support | NETGEAR
Check the section in the manual Factory Settings.
You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
Cable Modems & Routers
gmangi
Feb 01, 2021Guide
michaelkenward
1. Amazon claims it is a netgear problem and they don’t open packages direct from their suppliers
2. As I said, netgear confirmed that it was registered to another user previously and yes, I had no option to set my own security questions. It seems with these 2 factors that the only logical conclusion is that I am in fact not the first user and I bought this new.
3. I did a factory reset, or hit the manual reset button on the router if that’s what you’re referring to as a hard reset, and it did not resolve the issue.
It was either netgear or Amazon, but someone screwed up, an Amazon says it wasn’t them, so???
