jsiria100's avatar
jsiria100
Help with internet traffic monitoring!!!
Hi, I live with 5 roommates and they all connect to the wifi using several devices each. As you can imagine, this creates tremendous lag and interruptions when I am trying to use my device. I was wondering if there is any way to set up some sort of QoS or regulating how much bandwidth each device gets while I am trying to game. I will really appreciate help with this as it is extremely frustrating trying to play while lagging or trying to do my assignments while the websites I need do not load. Thank you all for your assistance!
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello jsiria100
    There is no setting in Netgear routers that can do exactly what you are looking for.
    DarrenM
    • jsiria100's avatar
      jsiria100
      Is there no Netgear router that has a user configurable QoS at all?
      • DarrenM's avatar
        DarrenM
        Hello jsiria100
        Yes Nighthawk routers do have Qos not our cable modems but Qos can not set bandwidth caps on individual devices.
        DarrenM
