Duggs
Jun 24, 2018Tutor
I can't connect iOS to Brother printer
Hi all, I’m desperately trying to connect my iOS device to my Brother MFC-J625W printer. There is already a Windows laptop connected with a USB cable and by wifi to the printer and a C7000 Night...
IrvSp
Jun 25, 2018Master
Check this THREAD, last message. Suspect the Brother is holding old network information and thinks it is still on that network. Try the last message solution.
michaelkenward
Jun 25, 2018Guru - Experienced User
... and look for the app, or whatever Macs have, that manages the printer's connection to the wifi.
That is what I did to fix a neighbour's HP printer.
In essence, the issue has nothing to do with your router. It is up to the printer to behave itself and to connect to the wifi.
- DuggsJun 26, 2018TutorC7000 Nighthawk AC1900 Wifi Cable Modem Router
Hello Michaelkenward,
I downloaded Brother iprint and scan.
It detects the printer but gives me the weird error message I described.
Is there a better app?
I appreciate your help... so frustrated!
Best, Duggs
