C7000v2_User's avatar
C7000v2_User
Lan To Lan Connections
Issue with LAN to LAN Connectivity:
C7000v2 Cable Modem/Router (Windows 10 OS) Xfinity ISP
  • Modem/router connects to Internet in both wired and wireless modes
  • Modem/router recognizes all connected devices in wired/wireless modes
  • Each computer recognizes the C7000v2 device and connects to Internet
  • Computers hardwired or wireless connected to router cannot see or connect to each other
  • LAN printer not seen by any device other than computer physically wired (USB)
LAN worked fine on previous DSL modem but stopped when C7000v2 installed.
Is there some setting I am missing on C7000v2, ISP initalization, or Windows 10?
Any help is appreciated.
  • > Computers hardwired or wireless connected to router cannot see or
       "see or connect to each other" how?  Are you talking about Windows
    file sharing, or what?
    > wired (USB)
       What is this printer?  How is it connected to what?  Who can't "see"
    it, when you do what?
    • C7000v2_User's avatar
      C7000v2_User
      .With my previous DSL modem/router, all home computers were linked on a private local area network. I could access files on any computer and print to any printer on the LAN (files and printer sharing through windows 10). When I switched to the cable modem/router, C7000 v2, each computer could access the internet, but could not view/access any other resources on the LAN. The only change was switching the modem/router. I can no longer print to the LAN printer or access files on other computers. One printer is hard wired through a USB port on another computer. That computer can print fine. Another printer was connected through an ethernet cable. I can't access that printer either.
      When the ISP (Xfinity) activated the cable modem/router, Thre was a question if it should be set up bridge mode. I think they did not use the bridge mode. Could this be the reason?
      I do have a Leviton 8 port gigabet ethernet switch to expand the number of ports beyond the 4 on the C7000v2. This appears to work fine and gives computers connected to it access to the internet through the C7000v2. This is the same configuration I used with the DSL modem/router
      • antinode's avatar
        antinode
        Guru
        > [...] When I switched to the cable modem/router, C7000 v2, each
        > resources on the LAN. [...]
           When you change routers, Windows may see this as a new network
        connection, which, by default, would be considered "Public" (as if you
        had carried your whole LAN to the nearest coffee shop, and connected it
        to that network), and hence file- and printer-sharing would be disabled.
           You may need to tell all your Windows systems that their (new)
        network connection is "Private".
           I doubt it.  If the C7000v2 is your only router, then you should
        leave it in modem+router mode.  In modem-only (bridge) mode, you'd need
        to have a separate router (or else only one client device).
        > [...] I do have a Leviton 8 port gigabet ethernet switch [...]
           "gigabit", but that's fine.
