pricear's avatar
pricear
Looking for compatible wired router or how to make the current one work!
Hi - I'm interested in getting a wired (non-wifi) router that will not degrade my high speed internet signal from Xfinity (Pittsburgh) and that is compatible with my CM1000 modem. I purchased an inexpensive TrendNet (TW100) 4 port router and finally got it to work, but it seems like streaming is slower and fragmented. My husband works from home with on-line sessions so we can't risk the quality not being good. Cost is an issue, so less expensive options would be very helpful!
Thank you!
  • Not sure if NG has any wired only routers anymore. They mostly make routers with WiFi.
    I now that Ubiquity has wired only routers. You might look into the Edge Router X.
    • pricear's avatar
      pricear
      Yes, it worked great without the router. The trick is that I don't want a wifi router. I don't want the additional expense of that feature and I don't want the wifi functionality.
      Thoughts?
      • FURRYe38's avatar
