Ernien54's avatar
Ernien54
Model C3700v2 Slow Download/Upload speeds
Xfinity checked their end and now suggested for Netgear to send a "Hit"? to the router.
They ran tests on their end and made improvents on their end. No improvment from the router.
Router has been reset several times with no change
Download speed - 33.1 Mbps
Upload Speed - 12.5 Mbps
Latency - 49 ms
Protocol - IPV4
Can't find a netgear support nop. to call
  • plemans's avatar
    Are those speeds wired?
    wireless?
    over 2.4ghz or 5ghz?
    What device are you using to test speeds with?
    And what website?
    • Ernien54's avatar
      Ernien54
      The speeds are wireless using the Xfinity Speed test on my MacBook
      it is over 5G
      • plemans's avatar
        what speeds do you get hardwired?
        do you have a screen snip of the cable connections page (shows upstream/downstream power levels of the modem) and the event logs?
        that lets us check the signal
