Sotelokid's avatar
Sotelokid
Modem Router Dropping Speed. Netgear AC1750 Wifi Cable Modem Router C6300v2
Recenlty bought this modem and ive noticed my speeds will drop. When i do a reboot my speeds will come back up 200mbps+. Not sure what is going on but ive checked to make sure things are connected and what not. Once rebooted itll be good for like a day or 2 then till drop down to about 1.5mps to 4.5mbps. Any answers or replies will be good. I have comcast as internet provider. They tell me everything is good on their end. Tried netgear support but nothing yet...
  • plemans's avatar
    speeds drop over wireless, wired, both? Or 2.4ghz/5ghz? Details are important since we aren't there.
    when it drops, do you still pull full speeds over wired?
    Do you have a screen snip of the cable connections page and logs?
    I'd also recommend if you have any splitters, amplifiers, or attenuators in line to remove them from the coax line.
    • Sotelokid's avatar
      Sotelokid
      They drop on both ....wired and on wifi. its odd and yes let me get a snip and  i will post again. Thanks for replying !
  • FURRYe38's avatar
    Have the ISP check the signal and line quality UP to the modem.
      Sotelokid
      I forgot how to check that again..how do i go about ?  My isp told me everything was fine on their end, but of course they say it must be soemthing up with my modem.
      • FURRYe38's avatar
        If you have a android pad or apple pad you can install a free wifi analyzer there product app store and see what wifi neighbor signals are near by. Sometimes having lots of other neighboring signals can cause problems.
