jcortes63
Jun 13, 2015Aspirant
N600 docsis 3.0 wifi cable modem router static table size
Seems to be this router does not allow to create static ip address out of the scope of DHCP, I decided to create a range of static IP addresses using fictitious mac address in the upper section of DHCP, actually does not allow to create more that 10 static ip address, getting message :
"Table is full. Remove an entry before adding new entry."
Is this correct?
- Babylon5NETGEAR Employee RetiredCan you say which model of router you own please? N600 is a generic term.
There will be a limit on the number of Address Reservations that a router will allow, this can vary between models but is in the order of magnitude that you see i.e. 10 or 20 are typical limits. - jcortes63AspirantN600 WiFi Cable Modem Router
C3700-100NAS
I have never seen that kind of limitations, worse thing is that after reaching 10 static ip addresses and getting the message "table is full" if I delete and entry in the table and try to create a new one I am still getting the same message. - Babylon5NETGEAR Employee RetiredI believe the C3700 is an ISP provided router, Netgear can only change firmware with the agreement of the ISP, and the ISP decides on the feature set.
