CEV22's avatar
CEV22
NETGEAR AC1750 WiFi DOCSIS 3.0 Cable Modem Router (C6300)
Hi All,
I have a NETGEAR AC1750 WiFi DOCSIS 3.0 Cable Modem Router (C6300) purchased new in August and am outside the call support window. I need to remove an old serial number from a previous account to add a new Xfinity account.
I've seen threads though it seems like someone from the moderating team needs to remove the old serial account. I've emailed customer service and tried to log into my account to deregister. Can DM the serial number.
Thanks!
  • plemans's avatar
    I guess i'm curious why you think you need to remove a serial.
    Is it on someone else's account at xfinity?
    Xfinity should be able to add it to your account if its new.
    Was it previously registered?
    What exactly is going? A bit more clarity might help understand your issue.
    • CEV22's avatar
      CEV22
      I have been trying to work with Xfinity to link it, but they noted that after 4 attempts, Netgear needed to remove the serial number. Their exact feedback is: I am getting the error message that eq couldn't be added to inventory: The serial number already exists, so it may be linked to another account, that is the reason I am unable to add the modem on your account. Please contact your modem manufacturer".
      I had registered it to an Xfinity account that no longer exists in August, Xfinity has removed this account, moved to a new state and got rid of my internet, and got a new account recently when settling into a new state. This is my own EQ, not a rental from Xfinity.
      • plemans's avatar
        it shouldn't be a serial number you're giving xfinity but the mac address.
        And you have to make sure your giving the appropriate one
