carl321
Nov 02, 2015Star
Netgear C3700 on COMCAST - Please don't buy it !!
PROBLEM SOLVED ! As you may have seen ive been having alot of issues with this device. The solution is DONT BUY this device if you are with COMCAST !. Here is why: 1. Slow speeds on wifi were...
JohnJH1
Nov 04, 2015Initiate
I wish I had read this before I bought this router, but that was a year ago. I also have Comcast and have Blast. Hardwired into the router, I am consistently hitting 178 Mbps. Using wifi, 26Mbps. Well, it sounds like the router and Comcast is a bad combination.
