carl321
Nov 02, 2015Star
Netgear C3700 on COMCAST - Please don't buy it !!
PROBLEM SOLVED ! As you may have seen ive been having alot of issues with this device. The solution is DONT BUY this device if you are with COMCAST !. Here is why: 1. Slow speeds on wifi were...
pattyc78
Feb 05, 2016Aspirant
I am not good at this but any one have Any suggestions on how I can disable wifi on the C3700? I just bought an airport extreme because the c3700 wifi speed is very slow but i need an modem now. Any help? Thanks.
DarrenM
Feb 09, 2016Sr. NETGEAR Moderator
Hello pattyc78
You can turn the C3700 into just a modem and let your airport extreme do the routing. Go to Advanced-Administration-Router Mode then select No this should bridge your C3700.
DarrenM
- Drew2Mar 11, 2016Star
Well this is disapointing to see. I'm having a "firm ware issue" with another of their routers. https://community.netgear.com/t5/Cable-Modems-Routers/c7000-100nas-Internet-sync-problems/m-p/1060778#M2468
