Xavier007's avatar
Xavier007
Follower
Jun 11, 2022
NETGEAR GS108E Switch & Nighthawk CAX30 Compatibility
Hello NETGEAR Com!!
I would like to isolate my Guest Network (currently residing on the NETGEAR CAX30 WiFi Router/Modem combo) on the NETGEAR GS108E Swicth.  I'm currently using the Guest Network for my security camers.  I don't need them to stay there, but I do want them on a sepearte Network, able to communicate with eachother, but not the rest of the Network.  How can I get them on a seperate VLAN on the GS108E Switch?
 My NETGEAR CAX30 WiFi Router/Modem combo is currently connected to Port 1of the GS108E Switch with the following configuration- all of which can be chamged.
Any assistance would be greatly appriciated.
Cheers!
A-
1 Reply
  • michaelkenward's avatar
    michaelkenward
    Your subject says
    Neither of those is one of the Nighthawk WiFi Routers covered in this section.
    While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
    You might get more help, and find earlier questions and answers specific to your devices, in the appropriate sections for your hardware. That's probably here:
    Cable Modems & Routers
    or
    Smart / Plus / Click Switches - NETGEAR Communities
    Discuss Ethernet Switches Plus and Pro Managed
    In the meantime you could visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
    Check for various troubleshooting tips.
    You may have done this already. I can't tell from your message.
    I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
