NutgearsGrindin's avatar
Dec 30, 2024
Netgear Nighthawk 5ghz WiFi not uploading files
I have seen multiple threads about CAX80 Netgear Nighthawk not allowing people to upload files on 5g WiFi, I am also having this problem. I recently “upgraded” my modem to this device. I am only able to upload files on 2.4g. If I turn on my VPN, then I am able to upload on 5g. I can’t just run on 2.4g because the speed is awfully slow and downloading files takes a bit of time. I handle about 50 files a day downloading, then uploading. Switching back and forth is not productive at all.
Does anyone have a solution to this issue?
  • FURRYe38's avatar
    What FW is loaded on the CAX80?
    v5.x is most current version and is supposed to resolve that I believe.
    What ISP is the CAX80 connected too?
    What wifi devices are connected to 5Ghz? Brand and model#.
    Is Smart Connect enabled?
    What channels are you using for 5Ghz?
    Is MIMO enabled?
    Does problem happen if you diable AX mode on 5Ghz?
    • What FW is loaded on the CAX80?      Unsure where to find this info.
      v5.x is most current version and is supposed to resolve that I believe.     I have the most recent firmware 5.1.1.8
      What ISP is the CAX80 connected too?      Xfinity
      What wifi devices are connected to 5Ghz? Brand and model#.     iMac 2023 Apple M3
      Is Smart Connect enabled?       No
      What channels are you using for 5Ghz?     Channel 36
      Is MIMO enabled?       Unsure where to find this info.
      Does problem happen if you diable AX mode on 5Ghz?      Yes
      • NutgearsGrindin's avatar
        NutgearsGrindin
        Tutor
        Netgear AX6000 firmware:
        Model name: CAX80
        Standard: DOCSIS 3.1
        Wi-Fi technology: Wi-Fi 6
  • Anonymous's avatar
    Anonymous
    I was having the same problem on both my 2015 MacBook Pro and my 2022 Mac Studio M1 Max. On both devices, upload speed tests indicated fast speeds, and uploading files via gmail was fast. The issue was happening with file attachments on both Slack and Apple Mail on both devices. Anything over ~80kb would fail.
    As to FURRYe38's questions:
    What FW is loaded on the CAX80? V5.1.1.8
    What wifi devices are connected to 5Ghz? Brand and model#. See above
    Is Smart Connect enabled? Yes
    What channels are you using for 5Ghz? 36 (P) + 40 + 44 + 48 + 52 + 56 + 60 + 64
    Is MIMO enabled? Yes
    Does problem happen if you disable AX mode on 5Ghz?  NO
    In short, I had AX mode enabled; turning it off fixed the problem for me. I included the other info in case it helps someone else.
    Thanks FURRYe38!
      NutgearsGrindin
      Tutor
      Thank you for adding this information. I hope it is helpful for anyone having this issue. I set everything the same as yours and still have this issue.
        Anonymous
        UPDATE: Unfortunately, disabling AX mode only worked temporarily. As of this morning, Slack and Mail file attachments are failing to upload again. 🙁
  • FURRYe38's avatar
    Any progress on this?
