dmart's avatar
dmart
netgear nighthawk cax80 multi gig port keeps dropping connection
Hello
So this issue with the multi gig port dropping connection has me a bit frustrated because I can't figure out what is causing this issue. I have tried different Ethernet cables cat8, cat7 and I currently have a cat6a stp plugged in. The drops of internet are random throughout the day from a couple a seconds then it comes back and some days I have no drops. this issue has been going on for about a week an half. I recently build a new pc were the muti gig is connected to which I didn't have this problem for the two weeks after building the pc. Any suggestions are welcome.
Motherboard - Asus Rog Strix z790 - e gaming (which has a 2.5 Gbps Ethernet connection)
Internet Provider and Service - Xfinity Gigabit Extra (speeds up to 1200mbps)
Ethernet Cable - CAT6a STP (25ft)
  • plemans's avatar
    Does it happen using the standard ports?
    Have you tried a different device connected to the multigig port?
    Reason I ask is I had a qnap 10g controller that did the same thing. It'd drop multiple times throughout the day or with specific programs. It was a bear to troubleshoot as it ran fine on a 1gig line
    • dmart's avatar
      dmart
      It’s doesn’t happen with other ports and I haven’t plugged in other devices to the multi gig port. Also, I have noticed if the multi port keeps dropping connection it eventually goes down to 1gb. The light from the multi gig port goes from blue to white when that happens
  • FURRYe38's avatar
    dmart wrote:
    Hello
    Motherboard - Asus Rog Strix z790 - e gaming (which has a 2.5 Gbps Ethernet connection) <What is the brand and model# of the 2.5Gb ethernet adapter on the motherboard? Seen others reported problems with Aqtion and Marvell chipsets.
    https://community.netgear.com/t5/Cable-Modems-Gateways/Re-CAX80-Multi-gig-ethernet-port-dropping/m-p/2275575/highlight/true#M41365
    Realtek doesn't seem to have this problem with the CAX80. Be sure drivers are up to date for this adatper as well. Try a different adapter to test.
    Ethernet Cable - CAT6a STP (25ft) <Does this happen with a shorter cable to test?
    What FW version is loaded on the CAX80?
    • dmart's avatar
      dmart
      The motherboard has the 2.5gb connection built in, no adapter. I am using the Intel Ethernet controller and driver is up to date. Do you recommend me switching to Realtek? And I haven’t tried any Ethernet cable shorter than 20ft
      • FURRYe38's avatar
