chizwiz
May 05, 2016Follower
Nighthawk AC1900 compatibility with Comcast voice on separate adapter
I see that the description for the Nighthawk AC1900 says it's not compatible with bundled internet and voice serice. However, in my case I have Comcast Business internet and voice, but the voice coax is connected to a standalone Arris "adapter". Basically, the coax coming from my wall goes through a splitter, one of which feeds to my Comcast-provided modem/router/wifi, and the other goes to this VoIP device. If I replace the modem/router/wifi with this product, will everything work OK since the voice is already on a separate device?
Thanks!
1 Reply
- doraemonProdigy
Your voip is not connected in anyway to your existing modem right?
As you can see the modem router doesn't have a voip port.
Therefore, you should be able to replace it without a problem.
