Moscowsteve
Aug 27, 2017Aspirant
Nighthawk C6300 and FiOS Quantum Gateway AC1750 and Chromecast and other problems
Hi, ultimately i just want wifi to work in my house the easiest way possible that does not continuious die on me..
I've spent this month another 20-40 hrs trying to resolve the above three items (C6300, Fios Quantom Gateway, and Chromecast).. to various degrees of 'sorta-kinda-working-but not-really'
even searching the netgear forums for help only partially gets me there.. In that often times the advice says.. oh yea this does not work for the C6300, you need to do XYorZ but then the advice does not work (like to set up it as a AP mode. there is no AP mode on the advance tab, nor a "use other operating mode first"..
anyway.. what id like to know.. whats best way to set these things up together.. note ive gone this route b/c after years of trying to get wifi in house (powerline adapters, extenders, etc, the netgear seem to be best option, this of course was before the orbi option).. but i still have to turn off the c6300 so that my sony bravo tv does not loose connection 100+ times on a 30 min netflix show.. im assuming its b/c both routers are still on .. but i could be wrong. .and chromecast keeps dropping signal
1) is there a way to have the Wireless of the Fios Gateway and C6300 play nicely together.. if so.. how (screen shots would be great)
so, can someone walk me through how to get this up an running (possibly seting FIOS in brige, or C6300 in bridge, or C6300 in AP mode, or something else, and how to keep the Chrome cast from dropping the connection)
thanks
steve
- DarrenMSr. NETGEAR Moderator
Hello Steve
You would want to turn the DHCP server off on the C6300 It is under Advanced-Setup-Lan Setup and uncheck the box this will stop the conflict between the 2 routers.
DarrenM
- MoscowsteveAspirantDarren thanks for reply. Inder advance i see wireless settings, port fwding, dynamic dns, remote mgmnt, upnp, usb settings , and ipv6. Now when i look inder all of them i only see under dynamic dns. The check box use a dynamic dns service and its not currently checked. Hummm. Checked again. Under advance/ setup/ lan settings the box use gateway as dhcp server is checked. Assume i am to uncheck. When i do this i loose ability to loginto router using routerlogin. So an i still able to login?
- MoscowsteveAspirantHumm. Netflix still had errors while c6300 on network.
