Pat700
Aug 10, 2018Follower
Nighthawk C7000 parental control
Hi all,
Apologies for a simple question - I am about to buy a Nigthawk C7000 so that I can add parental controls to my Virgin Media Hub 3.0. Apparently I can configure the hub 3.0 as a DOCSIS3 modem. I need to limit connectivity time for my kids. (The virgin hub is not good for this according to newsgroups).
Can anyone spot a flaw in my plan or does this look like I’m buying the right NETGEAR router? Specifically, will the C7000 work as a DOCSIS3 router, and does it have good time-based parental controls? My research suggests that the answers to both these questions is yes, but I’d really appreciate some confirmation from those with more experience before buying.
Many thanks in advance.
1 Reply
- vkdeltaNETGEAR Employee Retired
dont buy C7000 for Virgin Media. It will NOT work. it is not EURO DOCSIS certified.
you need to look for R7000P and connect behind Virgin SuperHub. Also change the superHub to MODEM MODE.
