jrayner
Sep 13, 2023Aspirant
Nighthawk CAX80 - Can't upload to Slack or Shotgrid
Hello, for the longest time I've been having trouble with my NightHawk CAX80. Purchased end of 2022, since then I've had trouble with uploads. Downloads are fine, but uploads fail 90% of the time, particularly for the Slack and Shotgrid programs I use at work. None of my coworkers have the same issue (remote working) so it must be my router.
I'm connected to ethernet, so the issue shouldn't be WIFI connectivity. I've downloaded the latest firmware, I've searched forums, people seem to have similar issues but no solutions. Also had our company's IT look at my computer and make sure there were no firewalls blocking things.
This is unacceptable for a $400 router that (other than speed) performs worse than my 8 year old nighthawk router.
Router/modem: Nighthawk CAX80
Current Firmware: Version V2.1.5.2
There's a similar WIFI issue that I also have that I think may be related, but really would expect things to be better over ethernet: https://community.netgear.com/t5/Cable-Modems-Gateways/CAX80-can-t-upload-5GHZ/td-p/2158905
Thanks, any help greatly appreciated.
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-routerWhat ISP speeds UP and Down do you pay for from the ISP?
Who is the ISP the CAX80 is connected too?
- jraynerAspirant
Thanks for your reply -
ISP: Comcast/Xfinity
Download: 1000mbps
Upload: 45mbps
Cable DiagnosticStatus: Good
Action: Your setup looks fine. If you are still experience an internet issue, the Netgear Cable Knowledge Base can provide additional troubleshooting info.
Internet Access: Good
Downstream Status: Good
Downstream Power Level: Good
Downstream SNR: Good
Upstream Status: Good
Upstream Power Level: Good
- jraynerAspirant
- KitsapMaster
A couple of additional questions.
Do you have your CAX80 configured to use the domain name servers (DNS) from your ISP?
Does your ISP support IPv6 and do you have IPv6 enabled in your CAX80 configuration?
