- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
CAX80 can't upload 5GHZ
- Mark as New
- Bookmark
- Subscribe
- Permalink
Im having serious issues trying to get this figured out, ive tried playing with everything for teh last 6 hours to get my uploads to work in 5ghz mode. Im literally 25 feet from the router and any file over 4MB just doesnt upload on sites like Wetransfer or Dropbox, icloud, email etc.
For example trying to upload a 19MB file will progess up to 40% on weTrafsnfer then suddenly drop down to 12% then shoot up to 75% and then down to 27% etc.
This DOES NOT happen in 2.4ghz mode where i can uplaod anything... help please!
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Firmware version 5.1.1.2 is what everyone needs to push for to be released.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: CAX80 can't upload 5GHZ
Does this happen with a different wifi PC or laptop?
Do wired ethernet connections work for the upload?
Use a browser? Which browser? Try a different browser as well.
How do you have the 5Ghz wifi configured?
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Is Smart Connect enabled?
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Is Armor enabled?
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapter for a period of time after the factory reset then walk thru the setup wizard and setup from scratch.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Does this happen with a different wifi PC or laptop? YES
Do wired ethernet connections work for the upload? YES
Use a browser? Which browser? Try a different browser as well. Tried Safari & Chrome, Both fail on 5GHZ.
How do you have the 5Ghz wifi configured? Stock Settings
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz. Tried, No luck.
Any Wifi Neighbors near by? If so, how many? A few, live in condo.
Is Smart Connect enabled? No, however when enabled, upload doesnt work.
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings - already on.
Is Armor enabled? - no expired.
What Firmware version is currently loaded? latest, 2.1.2.6
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapter for a period of time after the factory reset then walk thru the setup wizard and setup from scratch. - Done, 100x
- Mark as New
- Bookmark
- Subscribe
- Permalink
"Is Smart Connect enabled? No, however when enabled, upload doesnt work." So 5Ghz upload works if you don't have Smart Connect enabled?
What channels are you using on 5Ghz and what channels are your nighbors using on 5Ghz?
- Mark as New
- Bookmark
- Subscribe
- Permalink
This is so frustataring,
Is Smart Connect enabled? I just enabled it and its hit or miss, contingent on applicaton I cant upload files! icloud mail = NOPE, Outlook = yes.
Wetransfer = NOPE, DROP BOX = YES.
What channels are you using on 5Ghz and what channels are your nighbors using on 5Ghz? With Smartconncet its on 48.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What version of the firmware are you running on it?
If it updated firmware (automatically), have you ever tried a simple factory reset/reinstall?
- Mark as New
- Bookmark
- Subscribe
- Permalink
2.1.3.5 just became available for the CAX80. I just updated and it got me this far. I don't know if it will be helpful for your issue as 5GHz always worked for me.
Something to try though...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Strange, i dont see that update?
Also, i bought a NEW CAX80, set it up and am habing the same issue..... on a NEW DEVICE.
SPENT 2 hours with Netgear support to no avail... in anycase maybe theres something wrong here in my cable connection?
Everything else on this router is bone STOCK, as in out of teh box fresh.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I didn't find it on Netgears support page.
I opened the routers setup web page, then Advanced/Administration/Router Update. I pressed the "Check" button, the router phoned home and found the update.
- Mark as New
- Bookmark
- Subscribe
- Permalink
A lot of times the auto update server gets the update first and then it goes to the support site.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Let see if we can get these pictures approved...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just updated and no luck. STILL have issues uploading to websites like Wetransfer.
However now dropbox is cool to upload to? now im super confused.
help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Did you factory reset the modem and setup from scratch after you updated?
help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have you tried a different DNS provider?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Startup Procedure | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Downstream Bonded Channels | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Upstream Bonded Channels | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Downstream OFDM Channels | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Upstream OFDMA Channels | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Extended Upstream Transmit Power | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Enable Extended Upstream Transmit Power | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Current System Time:Thu Nov 04 13:49:23 2021 | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
System Up Time:00:12:00 | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
- Mark as New
- Bookmark
- Subscribe
- Permalink
Here are my speedtests...
I'm with Xfinity, my plan is 1200 Down & 35 Up
5G - Upload Spikes to 9Mbps then drops... ive even seen it settle @ 1.5Mbps.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I had comcast send out a tech. We replaced teh Cable comming into my unit and still have issues. The problem here is with Netgear. And support is AWEFUL. Had to call multiple times and was told i would get a call back from higher level support and nothing.
I've never seen anything like this before and i've ALWAYS used netgear routers. Very disapointed.
for whatever its worth, the tech told me that he saw "FM noise", he was forign so his accent was a bit strong and i count exactly understand but he sure said noise and that the issue lies with teh unit.
what are the chances of having 2 bad systems? Im going to best buy to return this unit and get a 3rd... fingers crossed.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
just to put my concerns to rest i went back to bestbuy and bought another CAX80... same issue.
NO IDEA what is going on here. Comcast is 100% good from teh tap to my home teh problem is with teh router, perhaps there is a setting that needs to altered. Im exhausted with this.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is the brand and model# of these wifi adapters in the computers your using?
Have the drivers for these wifi adapters been updated?
Wondering if there is a problem between the CAX wifi and your wifi adapters.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I only have apple products.
2017 imac, and 2017 macbook pro all running latest macOS
I did have the issue on a windows 10 computer as well.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is the brand and model of the wifi adapter on the Windows PC?
Ok. I guess I should try my CAX80 in router mode and see if my Mac Book Pro 2018 sees same thing.
What are the current wifi settings set for on the CAX?
Smart Connect enabled or disabled?
Channels being used?
WMM enabled or disabled?
Any Implicit Beamforming and MIMO enabled or disabled?
- Mark as New
- Bookmark
- Subscribe
- Permalink
For the 5ghz network only, I'm having the same issue from my windows PC. I cannot upload to wetransfer.com/onedrive sync but I can do upload speed tests without visible issues.
I do not have this issue on my android phone using the same 5ghz network.
Disabling beamforming, MuMIMO, and AX does not resolve the issue. But it does upload more data before erroring.
Typically, it stops uploading at the 1MB mark.
Clean install of windows
Lastest cax80 firmware
No modem errors
Modem/computer have unobstructed line of site, about 20ft separation.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Does a wired connection exhibit the same thing?
No modem errors
- Mark as New
- Bookmark
- Subscribe
- Permalink
Netgear support is trash. They didn’t hella me kept asking me to do the same BS resets every time. I still don’t have a solution and I bought 3 of the damn things to make sure it was a hardware issue. Seems to be a software one.
Comcast came to my place and replaced all the lines and confirmed all good. I will never buy another netgear product after they kept tying to sell me extended services after failing to solve this issue. If you can return it I suggest you do so.
User | Count |
15 | |
8 | |
7 | |
6 | |
2 |
