Skrobbins's avatar
Skrobbins
No phone port on modem router
At the risk of asking a stupid question, how do I hook up my landline phone to my xfinity cable through my new modem router? There aren't any phone ports on the thing.
  • vkdelta's avatar
    vkdelta
    NETGEAR Employee Retired
    you need to buy C7100V for Phone support. It is voice enabled Modem Router.
    C6250 does NOT support XFINITY LAND LINE Phone.
    • Skrobbins's avatar
      Skrobbins
      Thanks for suggestion. Are there any less expensive options with Netgesr equipment? My Internet speeds are only 150 so I don’t need anything terribly powerful - just reliable and able to reach across my 100 foot house from the corner. Thanks
      • vkdelta's avatar
        vkdelta
        there is CM500V but it is Modem+Voice only. Not router/WIFI. you will need a CM500V + seperate router.
