crossroads
Mar 08, 2017Aspirant
no wi-fi connections found
Wi-fi not doesnt have a valid IP configuration.....error message from my laptop. all other devices in my house work.
It seems to be working now. It was a simple fix of changing the power option to "maximum performance" and restarting my computer. I will see if this takes care of the problem. Thank you for your help.
Please give us the router model and the firmware it is running.
Though this sounds more like a PC issue than a router issue. Can you give us the exact wording of the error message (a screen shot would be best).
- crossroadsAspirant
N600 WiFi Cable Modem router
Model #C3700
The exact message: Wi-Fi doesn't have a valid IP Configuration
Also:
Problem with wireless adapter or access point
Wi-Fi doesn't have a valid IP configuration
Did you try connecting over ethernet, and making sure that worked?
Also, what version of windows, and what is the wifi adapter model in the PC?
