Czarnik
Oct 17, 2017Aspirant
Orbi & CG3000-2STATUS?
Can I use an Orbi with the CG3000V2 since it is the modem supplied by the cable coy? If not Orbi, what other mesh netwowrk technology is compatible?
DarrenM
Oct 19, 2017Sr. NETGEAR Moderator
yes this should work just fine I would bridge the cg3000 make it a modem only.
DarrenM
Czarnik
Oct 22, 2017Aspirant
Yes, but that defeats the purpose of having the CG3000 wifi capable. So the Orbi & CG3000 WiFi networks don't work or don't work well together? Better to "mesh" with other Netgear extenders? If so, which ones?
