Dworsky
Jul 29, 2015Aspirant
Putting N300 in "router only" mode with a Comcast Arris TG862 Modem/Router
I want to connect a Netgear N300 (model C3000) to a Comcast Arris TG862 router/modem/gateway that has very limited wifi coverage.
I need to put the Comcast modem/router in "bridge mode" to off ...
- Aug 03, 2015
Dworsky
I did some more research on the N300 unfortunately it cant be used as just a router/AP so the only way you could use the wireless off this modem is to make it modem for your comcast connection. Sorry that didn't work.
DarrenM
DarrenM
Jul 31, 2015Sr. NETGEAR Moderator
Hello Dworsky
You would need to connect Port 1 from the comcast modem to Port 1 on the N300. And the way to put the N300 into router only is Login to your N300 with www.routerlogin.net from here you will want to click on the advanced tab then click on advanced setup then device mode from here you can change it to just be a router.
DarrenM
Dworsky
Jul 31, 2015Aspirant
Darren....
Thank you VERY much.... I'll try it.
Edgar
- DworskyJul 31, 2015Aspirant
Darren...
Could you please be more specific of exactly where in the advanced settings I turn off the modem functions? (Also, do I have to do anything with DHCP settings or anything else?
thanks,
Edgar
- DarrenMJul 31, 2015Sr. NETGEAR Moderator
Hello Dworsky
Sorry i got the modem you have mixed up with another but i have attached a screen shot of what you need to have clicked and you do want to make sure the DHCP server is checked and active on the N300. And just make sure your New modem is in bridge mode. Let me know if this helps
DarrenM
Wonderful, Darren... thanks again.
Edgar
