Dworsky
Jul 29, 2015Aspirant
Putting N300 in "router only" mode with a Comcast Arris TG862 Modem/Router
I want to connect a Netgear N300 (model C3000) to a Comcast Arris TG862 router/modem/gateway that has very limited wifi coverage.
I need to put the Comcast modem/router in "bridge mode" to off ...
- Aug 03, 2015
Dworsky
I did some more research on the N300 unfortunately it cant be used as just a router/AP so the only way you could use the wireless off this modem is to make it modem for your comcast connection. Sorry that didn't work.
DarrenM
Dworsky
Jul 31, 2015Aspirant
Darren...
Could you please be more specific of exactly where in the advanced settings I turn off the modem functions? (Also, do I have to do anything with DHCP settings or anything else?
thanks,
Edgar
DarrenM
Jul 31, 2015Sr. NETGEAR Moderator
Hello Dworsky
Sorry i got the modem you have mixed up with another but i have attached a screen shot of what you need to have clicked and you do want to make sure the DHCP server is checked and active on the N300. And just make sure your New modem is in bridge mode. Let me know if this helps
DarrenM
- DworskyJul 31, 2015Aspirant
Wonderful, Darren... thanks again.
Edgar
- DworskyAug 01, 2015Aspirant
Darren,
Unfortunately, I could not connect the N300 (C3000) to the Comcast TG862 modem router in bridge mode. I found the "router only" setting on the Netgear device, thanks to your screenshot and made on other changes.
The Netgear router simply was not getting an Internet signal from the Comcast device with the ethernet cable connect port 1 to port 1. I tried EVERY combination of ports, e.g. 1 to 1, 4 to 1, 1 to 2, etc. And half the times I couldn't even get back into Netgear setup screen.
My guess is that some other settling has to changed to tell the Netgear N300 that it should expect to find the Internet signal on port 1. (This device only had two ports and one coax connection.)
Incidentally, I am easily able to connect a WNR-2000 Netgear router to the Comcast modem/router in bridge mode, and that works fine... but the range isn't the best. So the Internet signal is coming through port 1 of the Comcast modem/router.
Any ideas now of what to try? (Note: I will not be able to test this again for a month, as my friend won't be home.)
Thanks,
EDgar
- DarrenMAug 03, 2015Sr. NETGEAR Moderator
Dworsky
DarrenM
- DworskyAug 03, 2015Aspirant
Thanks, Darren, (even though it is bad news).
Edgar
