Lord-Boly
Feb 21, 2016Aspirant
Question about VLAN's
Hi, i am looking at getting a Ready NAS and connecting it to my network using a gigabit switch, and i'm curious if it is possible to put my desktop (ethernet) and my laptop (wifi) on the same VLAN t...
doraemon
Mar 04, 2016Prodigy
I'm thinking that the wired will have no problems as long as they're on the same VLAN ID but thinking about the wireless...
Perhaps if you have an AP wired to the switch and set it on the same VLAN ID...
- Lord-BolyMar 04, 2016Aspirant
Thanks for your help
Is there any way to have one AP connect a device too one of two Vlans depending on the Mac addresses?
If not can you use one AP to transmit two SSID's assigned two different VLans?
Thanks in advance
