AlColl
Oct 23, 2017Aspirant
RCN C6300 Not Pairing
I just moved from Xfinity to RCN in Chicago and am using the same Modem/Router. I reset factory settings, gave RCN my MAC Address, and after a few hours I am still not getting it to lock in on the int...
DarrenM
Oct 25, 2017Sr. NETGEAR Moderator
I would check with your ISP they may need to send a tech out to check your lines.
DarrenM
- AlCollOct 25, 2017AspirantThe lines have worked with two different modem/routers. Still not sure why my Netgear won't link up... maybe I have the wrong MAC ID? I don't have the original box or manual so I had to go into the system specs to find it... maybe it's not the right one though.
Is there a way I can find my Netgear MAC address with certainty? The one my ISP wants?
