AlColl
Oct 23, 2017Aspirant
RCN C6300 Not Pairing
I just moved from Xfinity to RCN in Chicago and am using the same Modem/Router. I reset factory settings, gave RCN my MAC Address, and after a few hours I am still not getting it to lock in on the int...
DarrenM
Oct 25, 2017Sr. NETGEAR Moderator
I would check with your ISP they may need to send a tech out to check your lines.
DarrenM
AlColl
Oct 25, 2017Aspirant
The lines have worked with two different modem/routers. Still not sure why my Netgear won't link up... maybe I have the wrong MAC ID? I don't have the original box or manual so I had to go into the system specs to find it... maybe it's not the right one though.
Is there a way I can find my Netgear MAC address with certainty? The one my ISP wants?
- DarrenMOct 25, 2017Sr. NETGEAR Moderator
Did you ever register it with netgear support if so you could access it in your netgear account.
DarrenM
- AlCollOct 25, 2017AspirantI will try that... if not, do I have any other route to find out the MAC ID?
- antinodeOct 25, 2017Guru
> one my ISP wants?
Is it not on the product label (as the User Manual (pages 10, 14)
suggests)?
Visit http://netgear.com/support , put in your model number, and look
for Documentation.
> [...] do I have any other route to find out the MAC ID?
Perhaps: ADVANCED > Advanced Home : Internet Port : MAC Address
(See User Manual, page 68.)
With any luck, they'll agree. Note that there's also a MAC address
for the LAN interface, but your ISP shouldn't care about that one.
http://www.downloads.netgear.com/files/GDC/C6300/C6300_UM_17Nov2015.pdf
