astronium
Jul 22, 2016Tutor
Router blocking me from random websites
So about a week ago I was able to access websites such as spotify and League of legends client. I tried to access these servers tonight and wasnt able to get any response: This site can’t be reached...
- Oct 04, 2019
Since its a Broadcom chipset based router I would disable MU-MIMO, on Broadcom based AC routers regardless of brand it can cause performance issues as Broadcom didnt do a great job of implementing MU. Secondly, MU on a 3 antenna router is pretty pointless as most clients have 2 antennas and for proper MU functionality to have 2 dual antenna MU devices reciving at the same time you need 4 antenna routers. The only AC router on the market that does well with MU is the R7800 (4 antennas), it uses a Qualcomm chipset, and its Synology equivalent the RT2600ac as well which uses the same hardware.
While not definitive, a successful tracert is a pretty strong indication that your router is not the source of this issue.
Did you verify that block sites or keyword blocking is not enabled on your router?
Do you have any kind of parental controls enabled?
