Tonkinite
Mar 21, 2017Luminary
Suggestions for future CM1000 mods & upgrades
Love my new CM1000, here are some follow on product suggestions
• Xfinity will be rolling out their 2G service in our area in 18 months or so, Netgear should consider a CM1100 version with two 1G WAN outputs, with optional 802.3ad (LACP) bonding, would require matching new routers with similar WAN ports (Nighthawk X11?).
• Similarly, an SFP+ WAN port could be added in addition, again, would require updated routers with similar support.
As far as the CM1000 firmware is concerned, would like Netgear to consider the following enhancements:
• Log forwarding via syslog and/or email and/or secure XMPP (formerly Jabber for those unfamiliar) IM, with optional triggers.
• A throughput/traffic panel, perhaps with a realtime graphical display of activity over the past minute
• Port scan of the lower 10000 ports on the modem shows only port 80 open, which means admin passwords are sprayed over the subnet and can be seen by anyone with a packet sniffer (Android device, jailbroken iPhone, bot on on a hacked smart device). This is a security exposure and should be fixed immediately. A similar issue exists with the R9000.
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello Tonkintie
Thanks for the suggestions you may want to post these in the idea exchange board where other customers can upvote the ideas.
https://community.netgear.com/t5/Idea-Exchange-For-Home/idb-p/idea-exchange-for-home
DarrenM
