khorning
Apr 16, 2019Aspirant
Support for R6080 Constantly Losing Connection
Our internet constantly has connection issues it disconnects and we lose wifi. Comcast has been out here umpteen times and nothing has been fixed. They say it's a router issue. We have had the router replaced. Very irritated with Netgear's support and the router itself. The wifi freezes, cuts out, resets, does crazy things. Today it asked us to re-activate comcast on the router.
If its asking you to reactivate you comcast account, thats coming from your modem and not your router. But a few details that can help us:
What firmware is on your router?
What modem and firmware are you using?
If you're directly connected to the modem, how are your speeds? What can you get directly connected to the modem?
Can you take a screenshot of your modems configuration page and your modems logs?
Please post about this here for your model router:
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk
- khorningAspirant
If its a problem with the router FURRYe38 was correct in the forum you should be posting in.
If its the modem, you should be contacting tp-link about it since its one of theirs.
If its the connection to the house, thats on your ISP.
I will say, you have quite frequent "Resetting the cable modem due to docsDevResetNow " those usually originate from your ISP resetting your device whether due do updates, the CMTs detecting problems, the device being reset (either by your or by itself d/t problems).
You said you replaced the router and continue to have the same problems. If you replace something and the problem continues, it usually isn't that device.
