illzoni's avatar
illzoni
Time to Replace CM1100?
Xfinity tells me my modem, CM1100, is 3 years old and is causing connection issues with my internet service.  Does this seem accurate?
DOCSIS® 3.1 Cable Modem (CM1100)
  • FURRYe38's avatar
    No. Someone at the ISP is trying to get you to spend money elsewhere.
    Please post a copy and paste of the modems connection status and event log page.
    https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
    https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    What is the brand and model of the host wifi router connected to the modem?
    • illzoni's avatar
      illzoni
      Thanks for helping.
      It's connected to a Netgear Nighthawk Mesh SiFi 6 Router (MR60).
    • illzoni's avatar
      illzoni
      I'm trying to post the copy/past, but the forum won't let me.
    • illzoni's avatar
      illzoni
      Apply             Cancel
      Frequency start Value
      This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect.
      Starting Frequency
      <tabindex=-1>Startup Procedure</tabindex=-1>
      ProcedureStatusComment
      Acquire Downstream Channel543000000 HzLocked
      Connectivity StateOKOperational
      Boot StateOKOperational
      SecurityEnableBPI+
      IP Provisioning ModeHonor MDDIPv6 only
      • illzoni's avatar
        illzoni
        <tabindex=-1>Upstream Bonded Channels</tabindex=-1>
        ChannelLock StatusModulationChannel IDFrequencyPower
        1LockedATDMA1716400000 Hz44.8 dBmV
        2LockedATDMA1822800000 Hz45.0 dBmV
        3LockedATDMA1929200000 Hz47.3 dBmV
        4LockedATDMA2035600000 Hz45.8 dBmV
        5Not LockedUnknown00 Hz0.0 dBmV
        6Not LockedUnknown00 Hz0.0 dBmV
        7Not LockedUnknown00 Hz0.0 dBmV
        8Not LockedUnknown00 Hz0.0 dBmV
        <tabindex=-1>Downstream OFDM Channels</tabindex=-1>
        ChannelLock StatusModulation / Profile IDChannel IDFrequencyPowerSNR / MERActive Subcarrier Number RangeUnerrored CodewordsCorrectable CodewordsUncorrectable Codewords
        1Locked0, 1, 2, 3193957000000 Hz-6.3 dBmV35.3 dB148 ~ 394760266017506687883
        2Not Locked000 Hz4.8 dBmV0.0 dB0 ~ 4095000
        <tabindex=-1>Upstream OFDMA Channels</tabindex=-1>
        1Not LockedUnknown00 Hz0 dBmV
        2Not LockedUnknown00 Hz0 dBmV
        Current System Time: Wed Nov 01 15:57:15 2023
        System Up Time: 0:55:30
