KyoshiFrostWolf
May 31, 2025Aspirant
Xbox Series X will not connect to CAX30 modem router (wired)
Just got a new modem router, the Netgear Nighthawk CAX30. Seems really cool, the wireless seems to be running fine. Main issue here is, the wired connection I have for my Series X isn't working at all, which makes no sense. It constantly acts like it wants to connect, then doesn't, and repeats. This is a bit infuriating as my previous modem worked with the console instantly upon plugging in the Ethernet. Not sure what is different here. I have tried power cycling the console twice and unplugged the modem, no luck. I'm certainly no expert on this stuff, but if my previous modem worked with no issues in regards to this, then this expensive piece of tech surely should reach that bar by default. This is a terrible first impression of this thing for me.
Any help at all is greatly appreciated. My apologies if this is a the wrong section.
do any other devices have issues connecting wired?
did you try a different ethernet cable?
also, you might try checking the xbox forums as there's a ton of posts on google about "xbox series x wired not working"
One common fix it theme I've seen is: Settings > Network Settings > Advanced Settings > Alternate Mac Address > Clear it
- KyoshiFrostWolfAspirant
So I realized something. When my laptop is connected, the associated port number on my modem is consistently lit. When my Xbox is connected, it is only sporadically lit, so this is most definitely a weird interaction with the Series X specifically. Not sure if that helps in any way in terms of info, but the issue is not the cable or modem. This also didn't happen with my previous modem so I don't think it is a hardware issue in regards to the Xbox either. It is so strange.
Does the same LAN cable that the laptop connected with, work with the Xbox or same issue?
If this same xbox did this with the last modem, maybe a Xbox issue as the problem seems to travel with the xbox.
My laptop connects just fine with the same cable and same port. I tried the alternate mac address clear, didn't work. Also tried resetting my console, didn't work.
