Ari_sydney's avatar
Ari_sydney
Genie Login issue x6 r8000
Hi All,
just wondering if anyone have similar issues..I'll be able to login to admin using browser but I'm unable to use genie app on both IOS and Android..I rebooted the router problem still persist..so frustrating..IMG_0017.PNG
  • Hi,
    Just found a bug in the latest Firmware from Netgear for the R8000 with regards to IOS Netgear Apps (including Genie).  Roll back to Firmware V1.0.3.32_1.1.21 and the bug goes away.  If you are using V1.0.3.32_1.1.25 (latest) you will have problems.
  • Yes.  It is also a problem for Android.  Bought a new X6 last weekend.  Worked great until it updated the firmware.  Now I get that message in Genie.
    • DexterJB's avatar
      DexterJB
      NETGEAR Moderator
      Hi all,
      This has been reported to engineering and is being worked on. We will provide an update once available.
      Dexter
      Community Team
      • HawtDogFlvrWtr's avatar
        HawtDogFlvrWtr
        This is still happening even with the latest firmware on 7/6/2017 even with V1.0.3.46_1.1.32 installed (latest). It would seem this isn't a prioritory fix. Especially when you purchase this router for the parental controls and the only way to set them is from the windows/mac/ios/android app, and none of them work.
  • I have the same issue. I can login in the first time following a router reboot. But then unable to access Genie on subsequent attempts. I am running the latest firmware on the X6 R6000. Very annoying.
  • I am having the same issue, Netgear when will this be fixed
  • Hi All,
    until now the problem still persist. Even the latest firmware and updated Genie did not solve the issue..very frustrating..was planning to give up and buy another brand of router..
  • Having same issue. Netgear support no help. Let me know if you found resolution. After this issue and experience with netgear support (horrible) ....I am planning on returning router as defective and buying different brand. FYI...I use Arlo cameras (like) and came from netgear 6300 which I had no issue with genie app. I had been happy with netgear....but this x6 is either defective or something. Not a happy customer.
