EricLevinson's avatar
EricLevinson
Initiate
Apr 07, 2021
Did a factory reset on my PLW1000 V2 - now default admin / password does not work
I was having erratric results from connectivity and decided to do a hardware factory reset by putting a paperclip in the hole and holding it for 15 seconds.
Unit reset ok - and I can connect to the network now using the default SSID and password written on the unit.
When I try to connect to the device's web page - I entered in the default username and password, "admin" and "password" and the unit says its invalid.
I also tried my previous password - and it too is invalid.
I had recently updated this to firmware .18 a few weeks ago.  I would like to put my SSID and password back.
Any help would be greatly appreciated.
  • antinode I already read the manual and it says the factory default username is admin and the factory default password is password.
    Yes - originally I was able to set the unit up with admin / password and put in a custom password - I tried that one as well and it didn't work.
    I just noticed there are two versions of this device PLW1000V2 - there's an older one (which I have) and a newer one that has the password set to password.
    The older one password is the same as the default wifi password.  I just tested it and it works.
    Thanks for your help.
  • > [...] I entered in the default username and password, "admin" and
       Ok.
       A "my previous password" which you had chosen, or something else?
       You might try an under-appreciated resource:
          https://en.wikipedia.org/wiki/RTFM
       Visit http://netgear.com/support , put in your model number, and look
    for Documentation.  Get the User Manual (at least).  Read.  Look for
    "Customize Your Network Settings", and "3. Enter the user name admin and
    the password. [...]".
       Did you try all the various possibilities?
    • EricLevinson's avatar
      EricLevinson
      Initiate
      • antinode's avatar
        antinode
        Guru
        > [...] I already read the manual and it says [...]
           Which "the manual"?  Read it again?  Fetch a recent copy, and read it
        again?
           As I read the manual, you have "older" and "newer" reversed, but, ...
        > [...] I just tested it and it works.
           So long as one of them works, that's what matters most.
  • Just wanted to say the same thing happened to me this morning and it was driving me crazy. I checked the user manual (which says the login is admin/password) and even asked ChatGPT - but using the default network password as the login worked. It was not enough to just 'like' your solution, so I had to create an account just to say THANK YOU! Still relevant in 2025
