Razor7Tech's avatar
Razor7Tech
How Can I Upgrade PowerLine Firmware?
Hello--
I have had several of the older v1 of the Powerlines with no issues for years. I just bought the nano v2 and I'm having trouble with one that keeps losing its connection and I have to keep resetting it to factory default to get it to work again.
I want to upgrade the firmware to see if that fixes the issue, and I've downloaded the current firmware, but I can't find any directions for upgrading the firmware.
If there is a utility, I can't find one for my model.
Any help is appreciated.
Thanks,
Stephen
  • michaelkenward's avatar
    michaelkenward
    What is the exact model number of these plugs?
    nano v2 is one of those generic labels.
  • Hmm. When I posted this it asked me. I guess it wasn't posted.
    It's the Powerline XAVB5200v2, I believe. I'm not where I can check right now. Definitely the 500 series.
      michaelkenward
      On the back. But you have to unplug it. Clever design!
      • Razor7Tech's avatar
        Razor7Tech
        Funny guy. can't tell if you're joking or you missed the details I posted: Powerline XAVB5201 v2
  • Yes, that is the model I'm trying to upgrade because I now have to reset it to factory default every time I try to use the computer it's connected to, and it's very frustrating because it's new.
    The back of the unit says XAVB5201v2
        Razor7Tech
        Thanks, but I have done all the typical layer 1 troubleshooting. It is the unit itself. I would like to try to install the firmware regardless of whether there is a new version or not as it is the last effort I'm going to make before returning them.
