surfjabroni1
Aug 31, 2015Follower
Newbie on powerline 500 additional devices
Hi everyone, I have the NETGEAR Powerline 500 + N300 WiFi and 1 Port Starter Kit (XWNB5201) set up to a wired connection on an apple TV device downstairs in my home. Now I want to make a wired connection a Mac upstairs. Can someone point me to the correct device to buy. Is it simply that I need to buy another Powerline AV500 device (eg I don't need to buy the whole kit again). Will it talk to the correct N300? So in effect I shouldn't need to configure anything as I did that the first time?
Any advice appreciated.
If the Mac upstairs is on the same electrical circuit as the powerline kit, then wireless does not have to come into it.
I have the same setup with the XWNB5201. I have added all manner of different plugs to it. They don't have to be the same speed, or even the same make.
At the moment I have a XAVB5201 pair. But that is one of many Netgear bundles that force you to buy a pair of plugs. The XAVB5421 pass through plug comes as a single. If you think you might need an extra network socket, there may be one available with a pair of LAN outputs.
1 Reply
