Annejb
Jul 02, 2016Aspirant
Powerline AV200 and WiFi = camping - need help
Hello We need some help for spreading the WiFi on a camping area. It is WiFi on the service room and a powerful router. We use the Netgear AV200 via the electricity net to spread the WiFi to ou...
TheEther
Jul 02, 2016Guru
You can purchase additional Powerline adapters to connect into your existing Powerline network. As long as they are all HomePlug AV/AV2 compatible, they should interoperate.
Annejb
Jul 04, 2016Aspirant
:-) Thanks. So can I use this; PowerLine 1000 + WiFi?
- TheEtherJul 04, 2016Guru
It should be fine.
