William10a
Sep 20, 2017Master
powerline lan adaptor pl1200
I realize that my wiring in the home and other devices may limit the true speed of the pl1200 but is the normal speed that people get that who use it, is it the speed on the box or slower and if slow...
michaelkenward
Sep 21, 2017Guru - Experienced User
It isn't easy to follow what this bit is saying:
William10a wrote:is the normal speed that people get that who use it, is it the speed on the box or slower and if slower how much slower?
The specified bandwidth of this plug is 1200 Mbps. Are you asking what people actually get?
William10a
Sep 21, 2017Master
Yes sorry mistyped yes what is the normal bandwitdh people are getting.
- William10aSep 25, 2017Master
In your option is the pl1200 the way to go or is there a better one trying to replace a 1gb cat6 cable with it in the present a 1gb switch and desk top computer using the cable.
72 mbps internet service but will upgrade to 1gb service when in area.
