Beep
Oct 31, 2015Aspirant
WGX102 and XE102 not connecting
I have the WGX102 and XE102 and have worked brilliantly up until now. Suddenly I cannot connect to them. Have reset everything green lights on everything but no Wifi. Please help
Hi Beep,
Does it work now with the latest powerline? If yes, then the issue is with the adapter and not the distance since it works with other powerline.
JamesGL
Community Team
- BeepAspirant
I seem to have a bit of an answer, if I change the socket that its in it works. It has worked fine on the socket it was in for years now its suddenly stopped. How do I get it to work in the old socket again?
- BeepAspirant
Does the distance degrade over time then because it used to work and now doesnt.
I have replaced it now with the latest powerline product.
