wamarlowe's avatar
wamarlowe
Wifi Extender Operation
I've just set up the extender (connected to router via ethernet cable) and added three hotspots across my apartment. I notice that the ethernet light only glows on the externder and not on any of the hotspots and in one room  (the most distant from the router) I have no or poor connectivity. Am not sure of the proper way to set up the 'network" - should the ethernet lights be on on each of the hotspots?
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi wamarlowe,
    Welcome to the community!
    Please indicate the exact model number/s of the devices involved in your setup for us to provide the correct recommendation.
    Dexter
    Community Team
    • wamarlowe's avatar
      wamarlowe
      Dexter,
      I have a powerline 1200-100uks* plugged into my router with the additional unit plugged into a wall socket. I have two powerline 1000-100uks* devices plugged into  other wall sockets. As mentioned the only device on which the ethernet light glows is the 1200 attached to my router. I don't understand the set-up procedure - as far as I could determine all I had to do was to attach the extender to the router and plugged the other devices into wall sockets around my apartment
      I look forward to your advice
      thanks
      Walter Marlowe
      [email protected]
      • michaelkenward's avatar
        michaelkenward
        Is that the PLP1200? Or the PL1200?
        The Ethernet LEDs on the "remote" plugs will not show until you plug something into them.
        There is a manual for the PL1200 somewhere at the end of this ink:
        >>>> PL1200 | Product | Support | NETGEAR <<<<
        See page 5 in the Quick Start guide.
        Remember, when adding extra plugs to an existing network, you need to follow this:
        >>> Adding a powerline adapter to an existing powerline network <<<
