andydrew's avatar
andydrew
XAV101 - problem after firmware update
I have two XAV101's. They were working fine when installed out of the box. But I wanted to set up the network security and I couldn't seem to get that to work with the buttons, so I installed the Configuration Utility from the CD with the product.
When installing, it said there was a newer version and did I want to install that - I said yes. It was version 2.x of the configuration utility (which I can't find on-line - I can only find 1.1 (1.0.0.7). In any case after installing the software advised me that there is a firmware update. So I installed the firmware update on both devices.
After installing the firmware updates, my units will no longer communicate with each other. The XAV101 that is plugged into my router (local unit) shows power light solid green and ethernet light solid green. Powerline light is off.
The remote unit has the power light blinking green. No other lights. I have left these plugged in much longer than 5 minutes to ensure they can link. They can't... So no longer working.
If I plug the remote unit into my router also I can see the configs for each XAV101 but they will not link via Powerline. Firware version in the Configuration Utility is INT6000-MAC-3-3-3348-00-2764-20080808-F-NA-02.
I have since tried installing the configuration utility 1.1 to see if I could flash the firmware to an older version - no firmware availalbe with 1.1. I can't find ANY firmware for the XAV101 on the Netgear site.
What can I do to resolve this? Is this firmware bad? Where do I get a previous firmware?
