netcora
Sep 05, 2015Guide
XAV5001 Raspberry PI Raspian
Hello I have a Raspberry PI I want to connect with my XAV5001. And when I try to connect it gives me an IP of 169.xxx.xxx.xxx range when I give ifconifg command and is supposed to give me an IP in ra...
JamesGL
Sep 09, 2015NETGEAR Employee Retired
Hi netcora,
Welcome to Community!
Does your Raspberry Pi works on a different wireless network? If you have an option to set an IP address manually on your Raspberry PI, then you can try to use same range as with the main router that provides DHCP.
JamesGL
Community Team
netcora
Sep 09, 2015Guide
Look the raspberry PI wireless is not connected because is an openvpn access point. The Ethernet IP is the problem. I configured also on interfaces configuration of Raspbian like dhcp and nothing. And on my router I tried via macid force to have an IP and nothing still giving an IP of 169.xxx.xxx.xxx. Suppose there is no wireless connections and what I want is to have internet via de powerline and the Ethernet only.
Thank you. What could be the problem?
- JamesGLSep 11, 2015NETGEAR Employee Retired
Does it work when it is connected directly to your router? This is just to isolate the problem.
JamesGL
Community Team
- netcoraSep 11, 2015Guide
In fact I use like that for now connected to the router. If the raspberry is connected directly to the router works perfect. I have a lot of XAV5001 then a failure of XAV5001 also is no considered because same XAV5001 in other devices works.
